Hi Everyone,
We've been doing alot of research on TVs and have decided that we want to go with a plasma. However, the problem is that we already have a cabinet that fits perfectly in our family room (we have a recess in the wall). So the dimensions are: 47.75 W x 32.5 H x 19.25 D.
A few questions:
1. Would a tight fit create any problems with heat? We would use the stand for the TV since it wouldn't be wall mounted so there would be room under the TV. Also there would be room behind for the warm air to go out and up.
2. Do you know of any nice plasmas that would fit those dimensions? Keep in mind we'll need to use the pedestal since it won't be wall mounted. Also, we could probably squeeze another .5 inch in the height department if that would make a difference. So far I've looked at the Pioneer 5070, Samsumg 5073, and the Panasonic TH-50PX60U but all are JUST BARELY larger than our dimensions. I'm talking like .25 to .5 inches in some cases. Darn!
Our viewing distance is about 9 feet from the couch and more than that from the dining/kitchen area so we think 50" is good. If we need to go down to 46" then we can but only want to do that if necessary.
Thanks in advance!!
-j
A few questions:
Thanks in advance!!
-j
