1 - 6 of 6 Posts
need some help choosing the best 55" LED tv for the money.
budget: $~1500
for: blu-ray movies, PS3 games, HD sports channels.
i have 3 options:
LG: 55LE5400
Sony: KDL55EX710
Samsung: UN55C6300SF
any suggestions? pros and cons?
thanks
budget: $~1500
i have 3 options:
LG: 55LE5400
Sony: KDL55EX710
thanks
Have you read the various threads for the three different models you are considering? That would be a fabulous place to start. How much research have you actually done? Why are those your only three options?
budget: $~1500
i have 3 options:
LG: 55LE5400
Sony: KDL55EX710
thanks
I'd suggest you first look at each in store and see which picture you like the best.
Discussion Starter · #5 ·
thanks for you reply,
i have seen all 3 TVs in the store, but the feeds they had wasnt very good,
cable or splitter they were using. so was hard to distinguish, plus i didnt play at all with the settings on all 3 to see the diffrences.
i narrowed my search to those 3 models, because those are currently on sale and are in my budget range, but i am open to any suggestions based on your recomendations.
i have checked the individual threads for the 3 models,
and well, is hard to say. they all are good sets, different oppinions and contradictions.
so i was hopping so hear some opinions from anyone that has compared those models or tried them.
thanks.
thanks.
since gaming is one of your uses, choose the TV with the least amount of input lag.
1 - 6 of 6 Posts
