I need advice on how to choose a wall mount for my LCD. I've never considered buying one before, but I'm going to be in need of one in another week or so.
This is what I have and would like:
1. Samsung LN-S4051D. It's a 40" LCD that weights just over 50lbs.
2. The manual says that the "TV accepts a 200 mm x 100 mm VESA-compliant mounting interface pad." I have no idea what that means.
3. I would prefer a fixed mount so that the tv lays parallel to the wall, not tilting.
4. I imagine that I will need access to the back of the tv every so often, so easy access to the back is probably a good idea.
What specifications should I look for in a fixed wall mount? Any brands that are better than others?
Any help would be appreciated.
