1 - 20 of 1269 Posts
ABSOLUTE ULTIMATE AV
Discussion Starter #1 (Edited)
3096846
DOWNLOAD: CHRISTIE GRIFFYN HC - DATASHEET
DOWNLOAD: SCHEMATICS & MINIMUM CLEARANCES
Pure laser. Pure performance. Pure excellence.
The Christie® Griffyn™ HC pure RGB laser projector. A technological marvel combining Christie’s superior electronics, our proprietary RGB laser illumination architecture with integrated liquid cooling, a sealed optical path for reliable illumination performance, plus revolutionary high contrast technologies, producing unrivaled video performance that will both astonish and impress you.
Ready to illuminate any surface with 15,000 lumens while operating at only 33 dBA / 36 dBA at full light output thanks to a self-contained liquid cooling system.
Design excellence.
Talk about engineering expertise: this compact and powerful all-in-one, omnidirectional projector is our first to offer our new TruLife+ electronics platform with all-in-one connectivity, eliminating the hassle of removable option cards. It also includes our new digital convergence that you can adjust via remote control for easy picture-perfect alignment. The Griffyn HC raises the bar in RGB pure laser projection performance.
Spectacular visuals
Astounding color performance, achieving >96% of the Rec. 2020 color space; more than twice the color of Rec. 709 and 50% more than DCI-P3, yielding breathtaking, more realistic color unlike what most people will have ever experienced before.
Groundbreaking 10,000:1 native sequential ON/OFF contrast, previously unheard of with 4K 3-Chip DLP, coupled with 1,100:1 ANSI contrast, for superior contrast and blacks.
No laser speckle thanks to the inclusion of pure RGB laser diodes of a wide array of multiple different wavelengths.
High frame rate (HFR) capability to achieve 120Hz at 4K resolution or up to 480Hz with HD.
Ready to transport your audience to colorful new worlds, the Griffyn HC not only raises the bar for RGB pure laser projection video performance but soars above it and is bested only by the Christie Eclipse 6DLP RGB Laser Projection System.
Key features
› All-in-one, compact design — No external chillers, laser racks or parts, and a manageable weight of 170lbs makes it the smallest and lightest high-brightness RGB laser projector available
› Digital convergence — Easily adjust convergence using the remote control to maintain a perfect image
› Omnidirectional — Operates in any orientation for unlimited installation flexibility
› Christie TruLife+ electronics — Delivers native 4K at 120Hz, or up to 480Hz with 2K resolution for unprecedented image fidelity
› Quiet operation — 33 dBA / 36dBA at maximum brightness
› Full range Light Output Adjustment — For all applications
› Expanded color gamut — Produces >96% of the Rec. 2020 color space for rich, vibrant and true-to-life visuals
› Superior contrast and blacks — Groundbreaking 10,000:1 On/Off and 1,100:1 ANSI contrast
› No Laser Speckle — No diffusors or screen vibrators needed
› Energy efficient — Operates on 220V single-phase power for lower cost of ownership
› Christie Twist — Built-in image warping and multi-projector blending software
› 4K lens compatibility — Compatible with most Christie 4K lenses
› Field-replaceable RGB laser light source — For easy service and replacement
Technical specifications Christie Griffyn™ HC
Image brightness:
15,000 ANSI lumens
Contrast: 10,000:1 On/Off. 1,100:1 ANSI
Display technology type: Dust-sealed 3DLP® (1.38")
Resolution: 4096 x 2160 (4K)
Operating Noise Level: 33 dBA / 36 dBA
Illumination type: RGB (red, green & blue) pure laser
Performance: 25,000 hours to 50% brightness
Orientation: Omnidirectional
Image processing: Christie TruLife+ electronics, 1.2Gpx/s
Frame rates:
• 24-60Hz standard
• Optional 96-120Hz 4K, 240-480Hz 2K scaled
Inputs standard:
• 4 x 12G-SDI
• 2 x HDMI 2.0
• 2 x DisplayPort 1.2
• Fiber (QSFP+) for use with Christie Link Transmitter (1 input/1 output)
• HDBaseT
• Terra® (SDVoE)
• Audio out
Warping and blending standard:
• Christie Twist™
optional • Christie Twist Premium and Twist Pro
• Christie Mystique™
• Christie Guardian
Lenses: (Specific to the Griffyn HC)
• 0.72:1
• 0.9:1
• 1.13-1.66:1
• 1.45-2.17:1
• 1.95-3.26:1
• 2.71-3.89:1
• 3.89-5.43:1 (lens not available in the USA)
Input line voltage: Single phase 200-240 VAC, 13A, 2600W max (8,870 BTU/hr)
Connector: IEC60320 C20 Inlet
Cooling: Liquid, self-contained
Laser class: Class 1 — Risk Group 3
Operating environment: 5-40°C (41-104°F)
Relative humidity: 10-80% non-condensing
Dimensions size: (LxWxH): 36.3 x 25 x 15" (922 x 635 x 380mm) not including lens
Weight: 170lbs (77.3 kg)
Discussion Starter #2 (Edited)
And here's here is my in-depth analysis of the full range contrast performance of the Christie Griffyn HC: 🙂
The Christie Griffyn HC crosses over the Sony GTZ380 at only 0.4% ADL.
Literally the entire contrast range 0.4% ADL - 50% ADL the Christie Griffyn HC has superior contrast performance as compared with the Sony GTZ380.
Ohhh cant wait, so this week means before monday ?? :p
  • Like
Reactions: ARROW-AV
Premium Member
HC = blocking chip like the Eclipse or a contrast tuned Griffyn? Anyhow, it´s good to see things are starting to move forward for projection, albeit in the (ultra) high-end segment for now...
  • Like
Reactions: clausdk
As Sgt Schultz says "I know nothing". I await Nigel's public disclosure of what I anticipate will be the most amazing front projector for home theater - only "eclipsed" by The Eclipse!
In what price range is the Griffin ? Close to the Sony GTZ380?
Also if someone dont need that much light output but really likes all what the Griffin offers is there a version with less lumens or can the lumens output be reduced ?
The light output will drastically drop once its tuned for more contrast. I’m expecting it to be in the 15k range.
Even if it does lower it in half(15K), since it is a RGB laser, it only drops to 80% at 30,000 hours. So hopefully this projector would be a theater for 10 years or more
The Christie Griffin 4k32-RGB came out last June, with a msrp I believe of about $110k plus another $10k plus for the lens. The HC model apparently is a modified version with the lumens tuned down and the contrast hopefully much improved, as discussed a tad in the past months on this forum and also the DCI Forum. Historically, when a commercial projector is modified some for consumer home theater purposes (Runco, Wolf, Vidikron), the home theater model is more expensive.
  • Like
Reactions: tnaik4
I didn't realize that. WOW! Our Sony and JVC lasers drop 50% at 20,000 hours.
  • Like
Reactions: ARROW-AV
With theaters closed Christie had to do something. Lets hope the the price is not out of reach. If they keep it low enough it could be a game changer.
Now that the pictures are posted I am betting it will still be very expensive.
Premium Member
Please post a Drawing of this Baby with Dimensions.
Especially interested to know the offset of the lens from the center = dimensions.
