Status
Not open for further replies.
1 - 3 of 3 Posts
Way back in the posts a couple of you had a way of using the RGB input on the Sony VPH-1020QM crt projector(YES don't laugh but I only paid $100AUD including the controller)using a circut to hold a steady picture.Can anyone help with the circuit so I can improve my current picture using the composite input to the RGB input?Since I have found this forum I am learning every time I log on.
Sharp and Detailed Video to you all.
Steve:D
Discussion Starter · #3 ·
Sorry about the confusion,I am currently using the composite input. I would like to use the RGB input on the projector from the RGB output from my DVD player. In this forum way,way way back someone had a circuit that gives the sync signal for a stable picture.(I will go to try and find it and hopefully explain it better) the Sony projector has 5 terminals for the RGB input.R,G,B,HD,VD.
Steve
1 - 3 of 3 Posts
Status
