Status
Not open for further replies.
1 - 4 of 4 Posts
· Registered
See link:
http://www.gizmag.com/go/3271/
Link might be busy since it was slashdotted - try every now and then.
Was wondering if it can be used for CRT PJs, or if they can be made to be larger or not. Would be a cool setup though
· Registered
Discussion Starter · #3 ·
From the article (RTFA):
Looking more like space-age satellite dishes the speakers stand an impressive 1.65m high by 0.92m wide by 0.72m deep. The whole system sells for £25,000 of which the speakers make up £9,999 of the price tag. They are driven by modified Lowther DX3's.
· Registered
Eh. Those images suggest that the projected video is opague and have nice contrast, but common sense, physics and the description says the image is see-thru and the "blackness" suggested by those images is a complete fraud.
A rear projection system in a bright lit room like that will be nearly unwatchable, with the darkest available luminance level being equal to that reflected off the wall behind the device. What a stupid idea. Even for a bright digital I bet it looks washed out in nearly all daylight situations.
Edit:
Here you can find a video of the screen in action. I was right. It looks washed out. The image has no opacity. You can see right through the screen. What a useless technology!
1 - 4 of 4 Posts
Status
