Hi all,
I have a DALite 120" letter box screen. It is a snap and remains uncovered at all times. It is three years old.
I noticed shiny spots on the fabric about two years ago. Have used soap and water to try and remove them. The spots are a little bigger than a pixel. Can't see them unless you look at an angle up close. However when the projector is on, to the observant ones, there are several white outs. It is like burnt out pixels. If I wash with just water, the rest of the night, 90% of them can not be seen.
I have had my local dealer, HI FI Heaven, in Green Bay, WI out to look at it. The guy coming out to the house, can see the shiny areas but had no clue and when he asked the guys at the shop they were not sure either.
Smoke free home, no wild parties, because the dots remind me of opening up a soda can and spraying it from one end to another and letting it dry on. If I did not have them all over the 120" screen, I would of guess that, but that is not it.
Anyone with a similiar problem?
Or ideas what I can use on the screen? To this point I have only use water and very mild soap. It has not helped.
If you want to see the screen, it is pictured, however this picture does not show the dots. Thanks in advance for your input.
Don
Don
