I just picked up this projector used and it seems to have quite a bit of dust build up inside the projector when I look through the vents. The projector has been stored in its original box in a garage for a couple of years. The previous owner smoked in the garage so there is also a concern that that there may be some secondary smoke issues. It works fine but I do not have a screen yet so firing it up against a red wall was the best that I could do. For the price I paid for it and the extended warranty that it has it was worth the risk so I thought that I would see if it makes sense to open up the case and clean out the inside.
Hang a white sheet or other white substrate so you can get a better look. If you have any dust blobs or discolorations (with a white blank image send it in for service .. that is the point of an extended warranty isn't it?
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
AVS Forum
