Status
Not open for further replies.
1 - 6 of 6 Posts
I got an Extron RGBS distribution amp on ebay (hoping to try a 1031Q stack soon) that has some sticky gunk from stuck-on velcro. Are there any slick ways to clean it off? Maybe rubbing alcohol? The gunk is on plastic. I already cleaned of some sticky crap off of the metal piece with some paint thinner - worked great. Anyway, thanks!
Try vinegar, as a non destructive cleaner. Acetone will clean it for sure, but it will melt plastic and paint, useful if you have deep gashes in a pj's case, it rounds the edges of the gashes and blends the paint together.
If it's adhesive based, WD40 works great too...of course then you've got to clean the WD40...
I've had real good luck removing sticker and tape adhesive with a product called "GOO GONE". Doesn't hurt plastic and works great...
Dave
Discussion Starter · #6 ·
Thanks guys!
1 - 6 of 6 Posts
Status
