Hello!
How much space do you need in between the woofer and floor?
My floor is carpet over underpad over concrete in my basement.
When I first got my down-firing sub (Mission M3as), I noticed it sunk into the carpet under the weight. The sub has legs so the woofer was still off the ground but it seemed smothered. I felt like I was getting unclear bass and it just seemed to rumble and vibe underneath my feet which would bother me.
Since then I've attached the spiked feet and placed them on dimes to prevent them from sinking into the carpet. This added an inch more clearance and I noticed less vibration under my feet and clearer bass. I've been fiddling between a 80Hz and a 100Hz crossover. I now have about a 2" or so in clearance between the woofer and carpet.
I'm wondering if I should get something like hockey pucks under each spike and raise the sub a further inch or so off the ground. I wonder if that will help in the clarity of the bass?
Alternatively, I have a piece of MDF the size of my sub and thinking of laying that down and placing my sub on top of it with spikes and all. That way, I recover the distance caused when the sub sinks into the carpet. The carpet's really springy! Would the MDF also act as a decoupler? I would prefer not to feel the vibes under my feet. I guess I won't really know until I try but I'm new to this bass stuff and a lot of it seems to be based on theory. I've read more about wavelengths and frequencies in the last week than I did all during highschool it seems
Oh and another question: I use the YAPO mic that comes with my Yamaha receiver to configure my system. It seems pretty accurate and calculates distance spot on. However, when I run my test tones to check out how well the YAPO did after a calibration, the test tone coming out of the sub seems a lot lower than the rest of my speakers. For example, if I did it by "ear", the sub setting would be a lot higher than if I did it with the YAPO. Is that just a perception though and low frequency trickery?! Do most people who've correctly calibrated their subs with an SPL meter perceive the test tone coming from the sub to be lower than the other speakers? If not, then my YAPO is not doing a good job at setting the subs level.
Any help would be appreciated!
