Hi all.
About a year ago I made a VGA to RGBHV BNC cable, out of
Ixos cable and Ixos BNC's. The BNC's are these VERY fancy
gold-ones
When I made the cable, I couldn't help wondering if the Ixos
idea of using three(or so), little wires instead of one single
conductor is flawed. I mean, normally the very stiff single
conductor just fits right in, but the multiple very soft ones
from the Ixos sort of....well, it didn't feel right.
I've just been to the electronics store, and I bought some
75ohm cable(cheap, costs about 1$us per meter) and some
75ohm BNC plugs.
What do you think? Should I make a new cable, or the Ixos way
good enough? Multiple soft wires vs. stiff single conductor...gold
covered BNC's vs. normal?
Thanks for your time,
Nicholas
gold-ones
75ohm BNC plugs.
Nicholas
