Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
I am planning on making my own cables using Snap & Seal RCA connectors (e.g., SNS1P6RM) and Belden 7915A ( http://bwccat.belden.com/ecat/pdf/7915a.pdf ). Canare connectors seem to be the defacto standard, as does Belden 1694a, but I am wonderiing if they are the end-all-be-all of connectors/cable, or will other combos work well also?
My runs will be no longer than 25 feet.
· Premium Member
It's not a high stress job and what you are proposing will work fine while perhaps reaching the stage of overkill. You don't need the end-all-be-all of connectors/cable. Even RG59 cable works fine in that application and is more flexible. The stuff you're looking at has a minimum bend radius of 3" for example. If you already have tools available from another job, by all means use them. I wouldn't get anything special for the job.
1 - 2 of 2 Posts
Status
