Status
Not open for further replies.
1 - 4 of 4 Posts
Do they make any module to allow for coax output connections?
Glenn
Radio Shack sells RF modulators that will take one of the Red/White/yellow SD outputs of the Dish 6000 and modulate it onto Channel 3 or Channel 4, giving you a Type-F coax output. You should be able to get one for less than $30.
Kit
San Diego, CA
[This message has been edited by Kit_C (edited 03-27-2001).]
They recently had these on sale for $10. Circuit City also sells one for $30.
--- WCS
Discussion Starter · #4 ·
Does that create much of a signal drop? Would it be better to just use composite cables for a 100' run? Which will have less signal loss, coax or composite?
Glenn
1 - 4 of 4 Posts
Status
