They should be the same, and just labeled to be labeled, and not mix them up.
I can't imagine why a DVD player would need a surge supressor.
Originally posted by Version Yes, CATV and SAT are different frequences and should be routed properly. It is the same reason a cable TV splitter (5 to 1000MHz) will not pass a SAT signal properly. |
Originally posted by photogold There are no active electronics in the surge surpressor for coaxial cables. |
Originally posted by greywolf Nah! You can't split a Sat cable to 2 receivers because it also carries low voltage signals from the receivers to the dish/multiswitch. |
Originally posted by pad971 I believe that is true, but isn't there passive electronics (capacitors and / or inductors) to create bandpass filters tuned to the intended frequency range? If so, using SAT frequency bands in a CATV connection could shunt most the signal to ground? |
