I know normally for heating you have your cold air returns low to take the cool air from the floor out. It seems that with a theater too much heat is always the problem so would it make sense to locate the cold air return near the ceiling to suck out the hot air?
Right now I have two down firing supplies located in the bottom of the soffits about 2/3 of the way into the room. I was going to put the return center of the back wall either high or low.
