Hi all,
The AVS709 color-contrast-clipping pattern I noticed that Red, Green & Blue all clip at different points. Green has a blinking bar at 235 while Red & Blue are barely blinking at 233. Also, the 3 primary colors all clip at different points than the grayscale white clipping patterns. Is this a normal result or does it indicate an incorrect color balance?
Second. After going into the menu and adjusting both the main color setting and color CMS section (where I also made a minor blue tint adjustment to fade the bar at 235 to appear invisible), I was able to get all the primary colors to clip at the same point as the white contrast grayscale. I noticed little to no change on the results on the primary color/tint pattern setting after making these adjustments. They weren't dramatic changes, just minor 'bumps' to change the point at which each color clips and also matching the precise point that white clips.
I swapped back and forth between my old setting on ISF1 & the new adjustments on ISF2. I don't notice a direct A/B difference but when watching the new settings I would swear that some blue and purple colors are ever so slightly 'off' but again, when I go to A/B compare it to the old setting, I honest can't see a difference. Perhaps my instincts are noticing the difference or perhaps I have psychologically convinced myself that I should see a difference and therefore see what I want to see (ie, subjective bias is messing with my objective observations).
There is definitely a difference but can't say for sure if I like it. When watching HD Cable TV, the old setting looks normal but the new setting seems to really show any noise or distortions more glaringly. I have adjusted the TV to the sharpness pattern so strictly already that I know if there is noise, it's because the source video just plain sucks.
I am evaluating the new adjustments still but wanted to run this by the calibrators for an opinion on what I've done. Could my adjustments to get the white & color clipping patterns to match up without effecting the main color test result give a just barely noticable downgrade of the color quality? Or have I done something worth keeping and maybe just aren't completely used to it?
