How accurate are the colors for component cable input to component cable input (SD 480 and HD 1080)?
Originally Posted by sneals2000 Yep - the 601 vs 709 colour space issues are just going to run and run. |
Originally Posted by kjack The source colorimetry info is embedded within the bitstream and the HD-DVD specs indicate precisely how to handle the colorimetry processing. Since what is going on doesn't seem to meet the HD-DVD specs, I would hope the firmware upgrade will fix it. |
Originally Posted by Ilka Interesting. I was wondering if these types of tests are typically performed by manufacturers prior to release? I am surprised that something as basic as this (or is it?) could be overlooked. |
Originally Posted by umr That is tragic. |
Originally Posted by sspears This weekend Darin and I took a look at the color conversion of the A1. We found a few issues that may interest you. HD: HDMI to DVI: RGB This is the scenario where you see plugging the HDMI output of the A1 into the DVI input of something downstream, like a display. In this case the A1 must convert to RGB. The conversion used by the A1 for HD is 601, which is incorrect. |
709 is the correct matrix to use for HD. The player is using 601 instead of 709 when connected to a DVI display. We did not look at the component outputs, sorry. |
Originally Posted by imwho88 would like to know how bad to the PQ? |
Since what is going on doesn't seem to meet the HD-DVD specs |
Originally Posted by sspears The color primaires in the elemenatry stream is listed as 709 on all titles, which is incorrect as all films currently released are color corrected with SMPTE C primaries. Unless the metadata is correct, it is useless. I will create some 709 bars with 601 and 709 matrix info and see if this data is actually passed on to the device doing the color conversion. |
Originally Posted by sspears The color primaires in the elemenatry stream is listed as 709 on all titles, which is incorrect as all films currently released are color corrected with SMPTE C primaries. Unless the metadata is correct, it is useless. |
SMPTE |
Why do they use SMPTE C for HD content? |
