481 - 500 of 502 Posts
Hello, World!
Jumping over from the LG OLED thread where we just talked about the CR250-RH firmware upgrades...
So, I've not upgraded my firmware since purchase, and I'm not having any problems with my calibrations, that I'm aware of...
Have there been any critical updates since launch where perhaps I DO need to consider a firmware upgrade??
I'm currently only calibrating LCD, OLED TVs and SXRD projector, but have a JVC Z1 laser incoming in a couple of weeks.
Discussion Starter #484
Thanks. In that case I'll hold off.
Hi Mark. CR250RH at earlier firmware, they added new improved sync mode, so this affects readings in a good way, faster, more stable etc.
There also firmware update at past for CR-100 which improved a lot (sync) and also the near black measurement performance significantly.
There meter updates where any user can perform (this is why they make them available for download to public), but there some times where the meter or hardware has to come back to the factory, to install the newer firmware (which will require meter re-certification also).
Hello, World!
Do any of the public firmwares, eg the current one, need any of the factory ones first? Or are they completely different types of update? In other words, could I go ahead and do the update to the current firmware without worrying about the factory-only stuff...?
Discussion Starter #486
Hi Mark, you can update your meters with the firmware available online, no problem ;)
I understand how you load optional color matching functions such as the judd vos into the utility program but how do you tell the CRI app whether to use one or not?
I tried loading it into the utility app and assumed that the CR250 would just use it until it's removed but my x,y,Y results in CRI App are the same with or without it in the utility. I also unplugged the spectro after making changes for the changes to take from what I underststand in the manual.
I'm using a 65B6P and for all I know, the reading might be the same both ways. I don't know but based on a statement about Judd Vos adding about 10% blue, that appears to be more neutral to the eye.
Discussion Starter #488
Colorimetry Research CRI Installer Version 1.4.4 for Windows 32-bit / OS X 64 bit (28 November 2016) Released.
The installer packages include CRI App, Colorimeter Utility, Software manual, Remote communication manual, USB Driver.
Release Notes
New RGB Balance Interface
Added import option to merge multiple measurements into one workspace for data/chart analysis
Added option to create a color profile using a wizard
Added support for SyncModes PAL, NTSC and CINEMA in the CR-250
Updated the date(Day, Month) and time(Hours, Mins, Seconds) fields to have two digit formatting
Download Link
Discussion Starter #489
Colorimetry Research CRI Installer Version 1.4.5 for Windows 32/64-bit / OS X 64 bit (03 April 2017) Released.
Release Notes
Added calculation of reflectance with a reference illuminant in the Reflectance Mode
Add/Copy Color profile allows changing of units
Fixed a bug in the RGB Balance when matching target Luminance.
Tweaked the RGB Balance interface to be a little more user friendly.
Resolved the issue where the CRIApp exceeded the screen height.
Flicker measurements are reported in calibrated units whenever available.
Download Link
Discussion Starter #491
New CR-250 firmware released . Version 1.34
Sent from my SM-N910V using Tapatalk
Cool ;)
Colorimetry Research CR-250, CR-250-RH, CR-250-FP, CR-250-IR Spectroradiometers 1.34 Firmware Update Released
Release Notes
Added support for Sync Modes NTSC, PAL and CINEMA.
Fixed an issue that caused incorrect reporting of the error "Variable light level" when speed setting was Fast or 2x Fast.
Minor improvements and optimizations.
Download Link
On the CR250RH, synch modes of PAL, NTSC and CINEMA have been added to None and Manual with this latest firmware update.
So if you're using this on a North American display using a OLED panel that's 120hz, do you use NTSC which I'm guessing is 60hz or use manual and adjust the frequency to 120hz?
Edit: I think I may have answered my own question. NTSC is the old analog standard that was discontinued, so it would seem that I'd use manual and 120hz? or am I missing something here???????
Hello Jim
Ok...here is the way I understand the new setting.
PAL is 50Hz or multiples of that frequency
NTSC is 60Hz or multiples of that frequency
CINEMA is 24Hz or multiples of that frequency
so NTSC would work because 120Hz is a multiple of 60Hz
Hope that helps.
Later
RayJr
Ray....
Can you review how the Color Matching Function works in the utility program. I know we talked about it but for the life of me I don't remember what you said. Sorry. ...and I now see a CIE 2006 as a downloadable CMF.
Discussion Starter #497
Colorimetry Research CR-100 CR-200, CR-110 Colorimeters 1.34 Firmware Update Released @ 19 April 2018.
Release Notes
Minor fix to prevent some host applications from crashing when creating LUT’s.
This upgrade is non-critical and recommended only if the host application is crashing during LUT’s generation.
Download Link: http://www.colorimetryresearch.com/downloads/
Discussion Starter #498
Colorimetry Research CRI Installer Version 1.4.8 for Windows 32/64-bit / OS X 64 bit (07 May 2018...was Closed Beta from January) Released.
Release Notes
Updates to the Ethernet Option.
Fixed an issue where the UI was getting locked up when removing a meter while connecting to another meter.
Updated code signing certificates.
Download Link
Discussion Starter #499
Colorimetry Research CR-100 CR-200, CR-110 Colorimeters 1.36 Firmware Update Released @ 18 July 2018. (but released today @ public)
Release Notes
Improved repeatability when measuring high luminance values from HDR displays.
Download Link
Discussion Starter #500
Colorimetry Research CRI Installer Version 1.4.13 for Windows 32/64-bit / OS X 64 bit (31 October 2018) ...but released today for public download.
Release Notes
Updates to High DPI support.
Updated installer.
Download Link
