Originally Posted by CZ Eddie /forum/post/20768629
If you run a horn subwoofer from 20-30hz up to 80hz and combine that with a vented (or sealed) subwoofer system that runs from 5-10hz up to 20-30hz and then time align the two systems together, are you asking for huge problems?
These would not be co-located.
Is it at all do-able?
Please do not turn this thread into a discussion about distortion or horn vs. vented/sealed. That is NOT the topic of discussion.
The real answer is "it depends".
And by that, I am talking about the PHASE response of the different systems at all areas in which they overlap by about 10dB or more.
Crossovers do not stop the response at a particular freq. That is just a point on the rolloff curve. Also unless the freq response is flat (not very likely-especially when you put room gain into the equation), the electrical and acoutsical response will be different, making the "numbers" on the crossover off a bit-sometimes a large bit (think an octave).
It is the phse that makes or breaks how well the freq response of the different cabinets will add together (in phase) or subtract (out of phase).
Various degrees of "out of phase" will amount to different amounts of addition and usbtraction.
It is not just a simple matter of "time" alignment, as the various methods of determining "arrival" is based on various peaks, that may be based on the freq overlap areas or not. So it may not be of any revalance in the particular situation.
All that being said, it might work-or it might not, there are a lot of different variables that could only be determined by actual measurement IN ROOM of the particular cabinets in question or by listening and see if you like it.
