Fatw,
I just had mine installed on Thursday...it rocks. No WB or UPN HD feeds though...I'm curious if the box can decode OTA signals if I plug in an antennae.?
As far as cable goes, the guy brings a 'kit' that has component video, audio, coax digital audio, s-video cables and some splitters for audio if you need more than one output. They charge $30 bucks for the kit, so it's not really a bad deal. No DVI cable though...the DVI port is enabled when they first plug in the unit it will download the firmware for it. Takes about 10-15 minutes to update your box.
The guy who installed my HD box was pretty knowledgeable...do me a favor and when he comes to hook yours up ask him about the OTA channels...I didn't think to ask my guy when he came to install :-( Thanks!
James
Originally posted by fatw I am getting this installed soon. Comcast is supplying the box. What type of cable do I need to connect to my TV. My TV has both DVI and component inputs available. Do anyone know what output options there are on the box that comcast supplies? Thanks |
James
