Status
Not open for further replies.
1 - 4 of 4 Posts
When you go into the cable box's menu and you choose audio, what options are best for use with a Denon AVR-3802 receiver via an optical connection. I have been using the "TV" option, but I had a "techie" at Comcast tell me that he personally used "Advanced" "Heavy Compression" and "Matrix Stereo" for his home theater. I tried this but the sound doesn't seem as good. It sounds muffled.
I would continue using "TV" but for some reason you have to go back into the menu and refresh the setting before it will send a digital 5.1 signal to my receiver. You don't have to change any of the settings or anything, just hit enter and bam it starts broadcasting in 5.1. What's uh...the deal?
I like setting the DCT to "STEREO" and I do not mess with the "HEAVY" compression in advanced settings. Then just switch inputs on the receiver from DVD to VID1 for the DCT audio.
Todd is correct. If you use the digital audio port on the hi-def Motorola DCT's advanced compression has no effect.
1 - 4 of 4 Posts
Status
