1 - 3 of 3 Posts
Discussion Starter #1
I recently bought "last year's model" Samsung UN55C8000 3D HDTV. It's great. Along with it, I also bought their 3D starter kit with two pairs of Samsung SSG-2100AB/ZD 3D glasses. I am now considering buying the relatively new Sony BDP-S780 3D Blu-ray player. I am wondering if the Sony will be compatible with both the Samsung TV and the Samsung glasses. There is a particular reason that I want to buy this Blu-ray player, so if you can refrain from recommending other players that you like, I'd appreciate it. I just need to know if this exact player will be compatible with the other two items I mentioned above. Thanks so much for your help in advance.
j
Yes.
In terms of passing through a 3D signal - yes. In terms of HDMI sync compatibility - probably yes but some buttons may have different functions.
1 - 3 of 3 Posts
