Status
Not open for further replies.
1 - 4 of 4 Posts
I'm buying a Sony SDM-V72 widescreen and it has only one component (RGB) input. I want to attach both a DVD and the Cable HDTV box to this TV. Is there a combiner that accepts these six cables and has a three-plug output--so I can switch between the two input sources?
you need a component video switch to do that
Discussion Starter · #4 ·
That does sound like a solution to the multiple component input problem I'm facing, but I was hoping for something in the $15 range that was not electronic. Just a simple passive switcher as you can find for composite cables, for example.
1 - 4 of 4 Posts
Status
