Status
Not open for further replies.
1 - 9 of 9 Posts
I finally took the plunge and ordered the unit along with a 92
Da-Lite HCCV screen. My problem is, up until now I've been using a
RPTV and my dvd player was near the TV, so I used audioquest
component cables. Now, since it will be ceiling mounted, and will at least
be 15-20feet away from the dvd player, I was wondering what cables
do you guys recommend a progressive component in from my dvd player?
good question, i have the same question...
what good quality, but relatively inexpensive, 25 foot component cables do you guys recommend for use with the L300U?
thanks...
Discussion Starter · #4 ·
I searched around and saw a similar thread so I ended up going for a 45 dollar 30foot cable from s-video.com. I'm going to compare them with my audioquest component cables and see if there is a difference. Though there's no way I can afford audioquest cables in 30feet =)
I'll post an update as soon as the cable and the projector arrives, which should be about a week.
I have the svideo.com cables (30ft) and have been happy with them. They are very small and flexible, but don't let that make you doubt them. I have found them very easy to route through some surface mount cable channels.
It's great when something is good and inexpensive!
I made my own with RG-6 and gold 'F' connects with RCA adapts from Rad Shack. Works great for Composite also. Here's a pic.
Ditto on the SVideo.com cables. I have A/B'd them with a MUCH shorter run of monster component cables (6ft.) and there is absolutely no real difference. I tend to have a critical eye, and I would whole-heartedly recommend the Svideo.com cables. Don't let the price fool you!
-Tim
1 - 9 of 9 Posts
Status
