Status
Not open for further replies.
1 - 6 of 6 Posts
Does anyone make a cable with component plugs on one end, BNC on the other? I would rather not use an adapter. I hate extra line breaks even if "theoretically" no loss of quality can be seen.
bettercables.com
rhinocable.com
bluejeanscable.com
I have bluejeans cables with BNC going to my plasma. They are a good quality. My interconnects are bettercables - I believe they are better constructed but at a much higher price.
Do you mean RCA to BNC? Markertek.com can make very high quality cables for inexpensive prices. I had them make component cables using Belden 1694 coax cable and Canare 75 ohm RCA connectors. I think I read somewhere that Bettercables used Belden 1694 with a extra thick outer jacket. Call them and they can make whatever you want.
Another vote for Blue Jeans Cable. Good prices and good service for quality cables.
Jeff
I took the Pepsi challenge with both Better Cables and Rhino Premiums - the Rhinos were far superior for about the same price. The same test included Monster Z300 and Audioquest something-or-other. They were both about as good as the Rhinos, but twice the price. So I guess the real outcome was that the Better Cables were significantly worse than these others.
1 - 6 of 6 Posts
Status
