Status
Not open for further replies.
1 - 11 of 11 Posts
· Registered
I just got a BenQ 6200 and a Momitsu V880. The 6200 has a VGA input that I can run the component output from my Momitsu into. Unfortunately I just called around town and no stores have a component to VGA cable. So I was wondering if anyone had any suggestions as to a type or where I could find a nice one. I'll need one also that has a bit of length (I'm guessing between 2 and 3 meters). Any help you can provide is much appreciated. Thanks.
· Registered
Markertek
http://www.markertek.com/ProdList.as...&search=0&off=
By the way, they'll send you a catalog for free if you ask them. The catalog has more stuff in it than what is on the website. They probably have at least two other brands of VGA-component cables in the catalog. Call and ask for information or just get the new catalog if you're not in a hurry.
· Registered
None listed on their site. Doing a search for "vga" brings back No results found.
· Premium Member
I own the same DVD player. You can buy a passive DVI to VGA adapter for about $20 at any computer/cable internet store...much cheaper than a new cable.
The other issue is I think you would actually need a component to VGA transcoder inbetween the the component cable and VGA cable...so you would run a component cable from the DVD player into the transcoder, then a vga cable out from the transcoder to the projector.
Here's a link for an adapter:
http://www.markertek.com/SearchProdu...I%2D8700&off=7
Good Luck
Ron
1 - 11 of 11 Posts
Status
