Status
Not open for further replies.
1 - 3 of 3 Posts
What is the best way to convert component out of a progressive scan dvd player (in this case a Panasonic CP72) to the VGA (R B G H V) input of a crt projector (NEC XG110 LC)?
I have seen the Audio Authority converter for $160 or so.
Are there other solutions that I have not found that would be better. or less expensive. It seems odd to spend $160 to use a $160 DVD player. Maybe there is a better player with VGA out for $320 or less??
I have been reading many good things about the Panasonics progressive scan output and that is why I chose it to replace a Pioneer Elite DV-05.
Maybe there is a Component in card for the NEC?
Any and all advise is welcome, thanks.....
Banned
The A.T. converter sounds like the best bet. Or use a line doubler to convert the component signals to RGBHV signals (not VGA)
Im not sure if there are cards for NEC units?
Discussion Starter · #3 ·
I'm currently using a DVDO line doubler from S-Vid in to RGBVH but wouldnt I get a better picture using the Progressive output into the projector? If not, I should stick with the DVDO and the Pioneer Elite DV-05
1 - 3 of 3 Posts
Status
