Status
Not open for further replies.
1 - 3 of 3 Posts
I will be installing my FPTV soon.(Cinema 13HD maybe) I will be running componet cable to it, about 35-40', back of wall and above the ceiling. I know some of the options: Monster Video 3, Straight wire, bettercable and avcable.com. Most of my viewing will be DVD and HDTV. Any opinions on which to go with? Does spending more money always give you better results or is some of the cost in advertising (Monster)?
I would highly recommend Extron's private brand of 3 conductor cable.
It works very well in the installations that I do which use 1024x768 computer images at 100' or more.
You can order it with a VGA connector on one end and BNC connectors on the other. You can also order it with the BNC connectors in a bag and raw ends to make the pull through the celing and/or conduit much easier. Then you crimp on their BNC connectors. This also allows you to make the cable as short as possible.
Just my .02 as I don't work for them, just use their products.
drewman
1 - 3 of 3 Posts
Status
