Hi guys I need some help here if possible. I listen to my mp3's through my home theater system. I have been using a mini jack to rca adapter then running the rcas to the receivers cd in. I am using a cheap adapter and a cheap audio rca.
What is my best solution to improve the sound. I want to get the sound quality up towards the range of a dvd player playing a cd if possible. Ive noticed in my current setup it doesnt properly use the sub.
Which option should I go with:
1. Buy a better Mini to RCA cable
2. Buy a Sound Audigy Pro with the breakout box and hook up using a optical cable.
3. Any other options you guys may have
I would prefer to do #1 as its much cheaper but I want much better sound comparable to a cd player
Also what softward is best to use for mp3's?
