Status
Not open for further replies.
1 - 20 of 149 Posts
Trying to create a repository for general info on computer connections for Sony CRTs. I don't claim to be an expert at this, just an interested user trying to organize some of the interesting tidbits floating around on this subject in various places. So use all info here entirely at your own risk.
Much of this will be old news to HTPCers, but I thought a repository like this might be useful for others as well, not necessarily interested just in Home Theater, but also general computer connectivity for games, web browsing, etc. In the interests of keeping this thread on topic for the Direct View forum, it might be best to post any more HTPC-related comments in this other first-rate AVS forum. However, if anyone else has links and tips they'd like to add re basic computer connections for Sonys, please do.
I owe alot to AVS and it's members like Dan Bennett, Rick Bayer, dbett and others especially in the 34XBR800 thread. And hopefully this will return the favor a little.
Powerstrip Links
~ EnTech Taiwan: Authors of Powerstrip, a tool for creating custom display modes for video cards.
~ Karnis's Custom Resolution Guide for 1080i HDTV-HTPC-POWERSTRIP-RADEON
~ DEFINITIVE GUIDE: Displaying Custom Resolutions on HDTV! This is a bit dated but still has some good info.
Rage 3D Tweak
~ Rage3DTweak This appears to be an alternative to Powerstrip for defining custom display modes and resolutions on video cards. Haven't used it and don't know too much about it though. Some folks seem to like it though.
HDCP-DVI Links
~ DVI input on current TV sets Post #4 in this thread contains many of the relevant links I've found so far regarding HDCP-DVI inputs on new TVs.
~ DVI - A Practical Guide Great quide and thread. Lots of info.
~ Sony DVI/HDCP connect to a PC? Includes Ashley Saldanha's MonInfo in Post #4 for analyzing signals an HDTV DVI input will accept.
~ DVI connection to Sony 4:3 hs500 or hs510 series TVs. More from the Direct View crowd.
~ HTPC DVI ----- Hitachi RPTV Not Sony CRTs but interesting.
~ DVI Output issues with Sony HS-10 Not Sony CRTs but interesting.
~ DVI on Sony 2002 vs 2003
~ Is DVI all that amazing....really?
VGA to YPbPR Component Transcoders
~ Key Digital Systems KD-VTCA2 Transcoder
~ Audio Authority A960 Transcoder
~ DIY VGA to component transcoder Why not build your own, like Dan Bennett and others?
~ Digital Connection A retailor of the Audio Authority and Key Digital transcoders.
Video Cards with YPbPr HDTV Output
~ ATI Radeon 9700 Pro All-in-Wonder (North American version only)
~ ATI Radeon 9800 Pro All-in-Wonder (North American version only)
~ ATI HDTV Component Video Adapter This is a separately available proprietary YPbPr dongle that can enable component output for other specific ATI Radeon cards like the 8500, 9500 and 9700 series.
Calibration & Service Mode
~ Avia calibration disk
~ Video Essentials calibration disk
~ GWII FAQ For Grand Wega LCD projector, but with many pertinent ideas for other Sony displays as well.
~ KV-34XBR800 service mode
~ Tweaking the 34XBR800?
~ Some tips on Sony service mode Some of this info is dated and/or does not apply to current models, but still a few useful tidbits.
~ Lite Trintron Service Panphlet PDF Also dated, but covers the basics of the Trinitron service mode, including some geometry adjustments.
Comments on using "Jump" to expand 16:9 HD letterbox to fullscreen on 4:3 Sonys
~ So SONY 4:3s only scan HD in their 16:9 area?
~ Overscan Fix Starting at Post #17.
~ 16:9 Enhanced Question
~ Sony HDTVs not fully ready for future of HI-DEF.
XBR910
~ 34XBR910 pc resolution?
~ Hooking PC up to Sony XBR910 via DVI
~ XBR910 FAQ
More Related Links & Threads
~ HTPC Forum FAQ
~ Are HTPCs Worthwhile for Direct-View CRTs?
~ Signal Processing on Sony HDTVs Discusses various aspects of how vide signals are processed on Sony TVs, including how to bypass much of the A/D-D/A conversion applied to 540p/1080i on some models, and get 540p to display progressively instead of interlaced.
~ Anyone got a HTPC hooked up to the 34XBR800?
~ Sony KV-34XBR800 FAQ - Page #24 Comments on computer input with transcoders.
Many of the above are discussed in depth in other AVS threads BTW. So a search on any of these topics should bring up a wealth of add'l info on them.
Discussion Starter · #2 ·
After looking at some of the test patterns below, it became rather obvious that my poor un-calibrated TV had some color balance and grey level issues. The grey issues remain on the back burner, but I devised a temporary solution to correct the color using the attached image below created in Photoshop. This probably worked very much like standard SMPTE color bars, only significantly dumbed-down so someone like me could better grasp it.
The Theory
The basic idea is simple. If the color balance on an RGB monitor is correct, then any primary video color that contains, say, red should look exactly identical to other primary colors containing red when viewed with only the red phosphors enabled. Therefore, the primary colors of Red, Magenta, Yellow, and White should all look the same with only red phosphors active. And by the same token, Green, Blue, and Cyan should all look black because they contain no red at all.
If the color on the monitor is not balanced correctly, then the above relationships break down, and variations in shading which should not exist begin to appear. Here's how I used the attached RGB Color Corrector image to fix these variations and improve color balance on my Sony TV for a computer input via the DVI connection. This required a bit of experience with the service menu to perform BTW.
Preparations
First I loaded up the image onto the computer screen against a light gray backdrop (this will be important later). I opened my TV's basic User Video Display Menu and made sure Hue was 50%, and raised Picture and Brightness to around 75% to provide a bit more elbow room to work with. Then in the service mode, I transcribed the default values for 2170P-2/RGBS and 2170P-4/RYR, RYB, GYR, and GYB. FWIW, the defaults on my TV were:
RGBS=7
RYR=8
RYB=9
GYR=9
GYB=6
Step #1 Color Saturation & Blue Correction
Still in service mode, I went to item 2170P-2/RGBS and changed it to a value of 1. This disabled the red and green phosphors leaving only Blue. Then, I adjusted the Color (saturation) setting in the basic User Video Display Menu until the 4 dark squares on the left all looked uniformly black, and the 4 light squares on the right all looked the same shade of blue. This was the most critical step BTW, because all the other adjustments depended on Blue Saturation being as accurate as possible.
If a near perfect match could not have been achieved on the Blue squares with just the Color adjustment alone, then I probably would have tried tweaking the Hue slightly as well at this stage. The factory default Hue of 50% was about as accurate as I could hope for though. So I left that alone.
Step #2 Green Correction
Next, I changed the 2170P-2/RGBS value to 2, to enable just the Green phosphors. I adjusted the 2170P-4/GYR and GYB color decoders until the squares on the top looked uniformly black, and the squares on the bottom looked the same shade of green. To do this, I began by lowering GYB to 0. Then I raised GYR up to 15 and slowly brought it down until it reached the point where the dark squares matched. Then I went back to GYB and raised it until the green squares all looked uniformly bright. This got me into the general ballpark, and then I tweaked the two settings a bit more from there.
Step #3 Red Correction
When I was satisfied, I hoofed it back to 2170P-2/RGBS and changed it to 4 to enable just Red. Then adjusted the 2170P-4/RYR and RYB items until the dark squares were uniformly black and the light squares were the same shade of red. (The light grey backdrop and 75% Brightness came in handy here because without any green enabled, the service menu can be rather difficult to read.) Coincidentally, 15 (the maximum) was the value that worked best for both RYR and RYB on my TV.
Finishing Up
At this point all the hard work was done. However, I went back to 2170P-2/RGBS and cycled though all settings just to make sure everything made sense in the Cyan, Magenta and Yellow modes as well. Finally I reset RGBS to 7 and saved the new service menu settings, and adjusted the Picture and Brightness back to something more pleasing.
FWIW, these are the new values I arrived at for a computer connection via the DVI port on my particular TV. Since there are other color parameters in service menu that can effect the calibration of the Color Decoders, these values should not be considered universal. Accurate results can only be achieved by following a procedure similar to the one above. These are shown strictly as an example from my TV.
Color = 37 ticks (~58%)
Service Menu
RYR = 15
RYB = 15
GYR = 7
GYB = 4
My monitor has had no previous calibration though, and it has some issues with grey levels as well. Once those are addressed, it might be necessary to repeat this process again. For a quick and dirty solution though, it seemed to work very well. Colors from the computer input have noticeably greater richness, subtlety and depth than they did before on my TV.
The maximum RGB values in the RGB Color Corrector image BTW are 210, just to err on the safe side. (I tested images with several different levels of brightness, BTW, including RGB 255, and the results were always the same.)
Also, this correction was designed only to improve the color balance for the computer input on my TV via DVI. The RYR, RYB, GYR, GYB settings have a global effect though so for better of worse, they'll alter the color from other inputs as well.
And the particular values listed above may not translate well to other kinds of computer inputs, such as a VGA transcoder or the ATI YPbPr dongle. In brief tests I did with the dongle, I noticed for example that it had much greater color saturation on my TV than the DVI input. So the Color value of 37 above would probably be much too high for it. However, I think the theory of this technique should be applicable to basically any kind of computer input. Values may differ slightly depending on which display mode (Pro, Movie, etc.) and Color Temp is used on the TV as well, although I did not notice much variation in this myself.
It's possible this pattern could be used to loosely correct the TV's color from a DVD player as well, if converted to some format the player can recognize (JPEG, MPEG, VCD, DVD-RW, etc.). It would not be a substitute for calibration disks like AVIA or VE though.
I'm not very savvy about computer viruses and don't know if they can be communicated via an image file like this. So for this and other reasons, any use of this image and the above info is, as always, entirely at your own risk.
Discussion Starter · #3 ·
Following are some other test patterns I created in Photoshop. Like the above color corrector, these are based on an RGB palette rather than the YUV palette that may be used on some calibration disks, so I thought they might also come in handy for checking color balance, gamma, black detail etc. from a computer input. They probably don't have any correlation to IRE values, but 0% = RGB 0,0,0 and 100% = RGB 255,255,255 in these images.
I suppose there is a remote possibility that the 100% RGB Colors could damage a TV not designed to handle fully saturated RGB colors. However if you're running your computer's display into a TV, then you're already risking this anyway, unless you've taken steps to reduce the overall palette of the video card in your display properties. IAC, use these at your own risk. The 75% Colors should be roughly equivalent to standard NTSC color bars though, I think, and they have an RGB value of 191.
I'm not very savvy about computer viruses and don't know if they can be communicated via an image file like this. If someone (a forum mod?) could check just to be sure they're not infected I'd appreciate it.
Pattern #2:
Discussion Starter · #6 ·
NOTE: Post #133 contains more current info on how I have adjusted overscan on my own TV. Everything on my TV is calibrated for a single input and signal now though (for just my HTPC). A service manual would be very useful for this sort of thing. More info on that in my signature.
I've poked around other threads a bit and found that users of other Sony displays are working with some different settings in the service menu to adjust overscan than settings previously mentioned here (HSIZ, VSIZ, etc.). And with these new settings, I was able to achieve 0% overscan, perfectly fitting my computer screen with virtually no distortion at the borders, without utilizing the porch settings in Powerstrip.
A FAQ for the Grand Wega II Sony LCD PJ covers the following:
In the MID1 category:
MDHS Horizontal Size
MDVS Vertical Size
DHPH Horizontal Position
DVPH Vertical Position
And in the MID2 category:
DRHP Horizontal Position
DRHS Horizontal Size
DRVP Vertical Position
DRVS Vertical Size
voidvod84 also pointed out the following settings in the MID1 category in this thread:
MDVS Vertical Size
MDHP Horizontal Position
MDVP Vertical Position
And there was one other setting that proved useful to me in the MID3 category:
VDHP (This appears to scroll the image horizontally in 1080i mode.)
The default values of many of these settings are dependant upon what screen modes you're in. Some values will change depending for example on whether you are in 16:9 Full mode or 4:3 Normal mode, or a 480p or 1080i mode. They could also vary from video input to video input as well. So be aware of these changes when transcribing the original values before changing them.
My main interest is adjusting overscan in Full mode. From the above posts it's not exactly clear to me which position adjustments, MDHP/MDVP or DHPH/DVPH, are preferable for this. For the time being though, here's what I did to completely eliminate the overscan on a 1080i mode (960x540p).
First I restored the VSIZ, VPOS, HSIZ, HPOS, HCNT to their original factory defaults, since these were previously altered in earlier attempts to adjust the overscan.
Next I used the MID1: MDHS/MDVS and MDHP/MDVP to scale and position the image until the entire video frame was visible with a small black border around the image.
Even though the entire frame of the video image was now visible, some of my desktop was still cut off on the right side. So I used MID3: VDHP to horizontally scroll the rest of the desktop back into view, and re-center the image inside the black borders of the video frame. I probably would have prefered to do this with Powerstrip, but haven't had much luck using horizontal porches for this kind of thing.
Once ALL of the image was visible with VDHP, then I used MDHS/MDVS/MDHP/MDVP to tweak the picture to perfectly fit the frame of the TV.
I'm not sure if this was the right way to do it, but it seemed to work. As always, tweak at your own risk, and make sure to record the defaults first.
Thanks sincerely Eric (voidvod84) for pointing these new adjustments out on the HTPC forum.
Discussion Starter · #7 ·
Subject to change without notice.
Method of Computer Connection: DVI -> HDCP-DVI input
A word of caution that Sony does not really advise connecting computers to an HDCP-DVI input. Although I haven't experienced any negative consequences from this so far (knock wood), I recommend looking at this thread and the links therein, as well as the other DVI links in Post #1 and researching this further to familiarize yourself with the risks and real purpose of the port before considering such a connection. IOW, Don't blame me if your TV explodes. :)
TV: Sony 34XBR800 16:9 Direct View CRT
Display Card: ATI Radeon 9000Pro DVI
OS: Windows 98 Upgrade
Mobo/Chipset/CPU: IWill XP333-R/ALI/AthlonMP 1600+
Cabling: dual-link DVI-D
Display Driver: Catalyst 2.??
Monitor Driver: ????
Software: Powerstrip 3.4 (on trial)
Other equipment I've tried:
Radeon 9700ProAIW with YPbPr adapter
Geforce Ti4200
Geforce FX5200 (no go on my system)
Display Modes
[email protected] timing: So far results in a virtual desktop in any mode other 16 colors.
[email protected] timing: Achieved by directly editing the ATI registries, and also using the Custom 480p HDTV Standard mode in Powerstrip (with horizontal scan corrected to 31.5kHz). So far this is the only mode that appears to display in true 480p without conversion.
[email protected] timing: This is the only standard Windows mode that worked for me "out of the box" without reverting to a virtual desktop. It has a soft and slightly jagged appearance though, and appears to be converted to an interlaced mode by the TV. Other 480 line display modes such as 704x480, 864x480 seem to behave similarly. Overlays also don't work properly in the non-standard 480 line modes. They display with a black bar on the bottom. I suppose this might be fixable with newer Catalyst drivers though.
[email protected] timing: Achieved using the Custom 960x540p HDTV Standard mode supplied with Powerstrip.
Before the 540p/1080i bypass on my 34XBR800:
Flickers but is superior in PQ to the 480 line modes and requires minimal tweaking for sharpness, etc. Appears to be treated by TV as interlaced 1080i (IOW, alternate 540 line scans still seem offset as though they were separate fields), Overlays work good (to my amazement). Noticed some vertical phasing in the picture (which I believe originates in the TV's DRC/MID circuits) when using the original 960x540p/60Hz PS timing, Changing the horizontal sync to 33.75kHz, and vertical sync to 59.947Hz seemed to eliminate this.
After the 540p/1080i bypass:
540p now appears to scan progressively. I.e. no flicker and no offset of the alternate scans. Vertical phasing at 60Hz is no longer evident. See the bypass link above for more details on these changes.
[email protected] timing: Seems OK. PS Derived HDTV Mode. Seems pretty good for DVD viewing and no overscan.
[email protected] timing: Seems OK. PS Standard HDTV Mode
[email protected] timing: Seems OK. PS Standard HDTV Mode.
[email protected] timing: Results in virtual desktop so far.
The reason I suspect I'm not able to do 720p/1080i timings yet is because I'm still using Windows 98 and some older Catalyst display drivers.
Boot screens are visible on the TV.
ADU is a Super-Star.
The time and effort you put in, to bring us all these links for one thread, is much appreciated. The highlight for me was your Post#7, where it shows the other service mode entries to adjust over-scan. That alone has just changed everything for the better, those are the true over-scan properties to use for PC adjustment. Now I am using 640x480 and 1024x480 with true skill. Very nice work on your research.
1024x480 is a resolution that many PC games should support.
This is the 4:3 1024x480 timing I use, then only slight adjustments need to be made;
1024x480=1024,0,104,152,480,5,5,31,40000,7
Discussion Starter · #9 ·
Thanks, Dwe. :) And for the PS timing as well. When you get a chance, I hope you'll breakdown a little of your configuration as well so I can compare notes.
Still having difficulty getting the 720p and 1080i working, and not exactly sure where the problem is yet. Alot of possible suspects though (DVI port, monitor driver, video card, OS, PS timings etc.).
Ok mang, heres the system break-down Setup .
I get 720p/1080i working with power strip. I just add 960x720 in powerstrip custom and restart comp and my TV displays it with massive over-scan but -not virtual desktop-. A good trick to use is put your TV in service mode and it will always display what signal its recieving. When you change resolution it should show 480p or 720p or 1080i in top right corner. This is the timing PS gave my system 960x720=960,48,96,144,720,1,3,22,55860,1.
Make sure your HDTV is set to primary display in display properties and your crt as secondary when using power strip. When I reinstall my display drivers my HDTV always display 1920x540 (1080i) at first boot up.
right click your desktop;go properties; settings; advanced; adapter; list all modes button and you should see resolutions supported. Beside adapter tab click monitor and disable the check mark for hide refresh rates. This is based on CAT 3.4 running XP so if some tabs arent there then I assume its different then.
When adding custom resolutions to powerstrip just tell it what you want then hit add then restart system if it say. On reboot the resolution will almost always be working on the crt but not the HDTV. With the HDTV on (I do it this way, do this at all your own risks) go to advanced timing options, then under Vertical geometry, go to Total Line box, and bring the number to 500 - 510 area, you will then see your TV start to display. Thats just a rule if you add resolutions like 640x450 like I did. The trick to not need Power strip running with your modified res and geometry adjustments is to make all your adjustments then, go to the powerstrip folder and go to the ini file (open with notepad) scroll down tilll you find "custom timings" it will be displayed like how I put the 960x720 timing above, copy them all to another location then uninstall Powerstrip and your display driver, then reinstall them, go to the locatin where you saved your custom timings, copy the entire line of any given resolution then in Powerstrip where you add customs, you will see two symbols at bottom right corner, hold your arrow over them and click the one that says "paste timings from clipboard", do that for each of your resolutions first before restarting comp. On restart your timings with you geometry adjustments will be in registry, so you dont need powerstrip running again. As long as your programs support the resolutions you made you can run them and they will use the PS made geometry corrections you made.
General ideas to get people started. As always, its advised to read the
Karnis Guide I knew nothing of HDTV timings and res and power strip, till I read that.
Discussion Starter · #11 ·
:cool: Rockin! Thanks for the tremendous tips, Dwe! Definitely gives me somethin to chew on.
This might explain why 1080i is given me some trouble as well. Sounds like the interlacing option in PS needs to be tricked into workin with DVI.
Discussion Starter · #12 ·
The GWII FAQ also discusses settings for color balancing the greys in the 2170P-1 category:
RDRV (Red Drive, etc.)
GDRV
BDRV
RCUT (Red Cutoff, etc.)
GCUT
BCUT
And the color decoders in 2170P-4 that many here have used for adjusting red push:
RYR
RYB
GYR
GYB
To give credit where it's due, this thread is where I first found RDRV, RCUT etc. mentioned.
Discussion Starter · #13 ·
Thought these also might be useful for gaging color balance and drift at different levels of brightness.
Pattern #6
Discussion Starter · #15 ·
The GWII FAQ referenced in Post #1 above mentions these MID5 category items:
MHLY
MVLY
MYHL
These appear to be separately adjustable for each display mode (Pro, Movie, etc.).
Changing the first item, MHLY, in Pro mode from the default of 1 to 0 seemed to improve the clarity of DVDs for me. According to the FAQ this should disable the horizontal Y low pass filter.
Pro mode is the only display mode which has this low pass filter enabled. And I think this could be partly why it's always looked a bit fuzzier than the others, FWIW.
Discussion Starter · #16 ·
Originally posted by debennett2 here
Adu, although you are on the right track (you have come a far way very quickly), the MID1/2 adjustments probably aren't the best route to go for adjusting for overscan. I have tested these out and, although they seem to be "better" as far as getting less overscan, you will notice that there is a general out-of-focus look compared to using hsiz/vsiz adjustments. I'm not sure how to account for that, but you will also notice that the MD adjustments also require you to reposition both vertically and horizontally when you resize whereas the Hsiz/Vsiz adjustments don't usually require any adjustment due to how the resize is done. It seems as though the MID1/2 adjustments stretch the image from one end whereas the VISZ/HSIZ adjustments pull from either side simultaneously.
Thanks for weighing in on some of this, Dan. Hope you don't mind me bringin this over here since this all ties in nicely with computer input.
Re the MID1/2 new overscan adjustments, they do scale differently than HSIZ/VSIZ, but since there's a wide range of adjustment with the MID1/2 positional adustments, I don't really see this as a problem. The MID1/2 position and scaling items seem designed to work in tandem. Although they allow wider range of adjustment than HSIZ/SIZ, the MID1/2 adjustments are mode-dependent, while HSIZ/VSIZ appear more global in nature. So greater care has to be taken when adjusting/recording the MID1/2 settings.
There are many ins and outs to the MID1/2 adjustments I don't fully understand though. Which functions are best for which display modes and so forth. When I tried using the DHPH/DVPH to adjust position on a 1080i Full mode for example, they threw off the centering on other modes. There may be a very good reason why they do that. But I haven't sorted it out yet. That's why I went with just the MD.... settings on 1080i for now.
If you need to switch between many different screen modes on the TV, tweaking the MID1/2 adjustments until they're all correct may be rather labrious. I'm trying to limit myself to only a few: Full 16:9 1080i and 480p for computer input, and Full 16:9 480i for DVDs.
I'll take a closer look to see if I notice the out-of-focus look you mention as well with the MID1/2 adjustments, and try to figure out if some of these settings are altering the vertical or horizontal resolution, degrading the image quality. Some softness could possibly be attributable to greater overlap of the scan lines in the tighter underscanned image. Lowering the Picture setting (and blooming) may help with this a bit. It's much easier to tweak the MID1/2 adjustments to get a good fit of my computer screen with minimal distortion though, so I'm hoping those will do the job.
Another item I've looked at is MID3/VDHS for horizontal scaling. This item appears a bit touchy though, and easily throws the picture out of sync. So I'm not sure I should be messin with it. As always, use at your own risk.
Discussion Starter · #17 ·
As far as adjusting for red push/green push. This is easily done through the Avia "color decoder check" (through settop player of course). You still would want to turn off colors as to only have the color being tested on, thus not requiring a filter, but this way, you know you are getting the proper color to the display for testing. Make a note that turning red all the way down actually requires turing the values all the way UP. Also note that some settings must be saved (Muting+Enter) before moving on to the next section of the service menu or the previous setting will go into effect (something I found when blowing through the service menu the other day).
After all the basic adjustments are made to overscan, color push, and then the basiic video adjustments are made, THEN put that DVD into your computer's DVD drive and make any adjustments either via the overlays (for WMP you will need to have it playing (paused it ok) in order to make adjustments to the overlay that will stick when playing WMP again.) or make adjustments via Powerstrip. If, in fact, you need to make adjustments in Powerstrip to color, hue, or brightness, I would suspect something is wrong with the transcoder/converter you are using and not point fingers elsewhere.
I'm glad you pointed these things out, Dan. How one approachs calibration apparently depends alot on the different sources and applications involved. Since I don't currently have a DVD player on my PC or the AVIA disk, the quick fix above was simply a temporary solution improvised to get the color of RGB applications on my PC more in the ballpark. (Ironically, the color on my TV is probably now better calibrated than my computer monitor.)
This quick fix definitely isn't rigorous enough to take into account all configurations of computer and video input though. Unless one intends to route all video sources to the TV through the computer (as with an HTPC), there is perhaps an inherent flaw in the idea of correcting the TV to improve the picture from the computer input, because this will alter the color for all the other inputs on the TV as well, and not necessarily in the most constructive manner. If the original color decoder values have been correctly recorded though, undoing any damage should be a fairly simple matter.
Good point re the RYR, RYB color decoders.
Discussion Starter · #18 ·
My self-made transcoder gets it's sync information from the PC (powerstrip in specific) which allows me to get fairly accurate sync width for either 480p or 1080i (these are totally different. SD timing/480p H-sync = 2.3us+/- 5% V-sync = 6 lines and HD timing/540p/1080i H-sync = 0.858us +/- 5% V-sync = 6 lines ) For example, if your transcoder/dongle/whatever doesn;t have some kind of switch to distinguish between 480p material and 1080i material and/or you don;t notice a very noticeable difference when messing with sync width in Powerstrip, then the transcoder is stuck at a fixed sync width predetermined by the manufacturer. This is not good since there is a very noticeable difference between the two just in brightness alone. The best route is to make your own. We are getting through designing a new DIY (and final) transcoder that will do the following:
1) VGA passthrough (the current design has this as well)
2) Direct Powerstrip manipulation of sync widths
3) both color standards through automated switch (basically, when creating custom resolution, you setup 480p resolutions (SD-type) with a negative sync and 1080i (HD-type) resolutions with positive syncs. The transcoder then switches to the correct SMPTE color conversion based on what polarity sync it detects....no switches required)
4) A neat little case!!
I'm not sure I'm followin all of this, but it sounds pretty interesting. So basically you're using the sync polarity to automatically change the color correction within Powerstrip, right?
I'm afraid I'm still a bit of a Powerstrip neophyte. If I could just get a true interlaced 1080i mode workin thrugh DVI, I'd be happy though. :)
Discussion Starter · #19 ·
After color correcting my 34XBR800 TV for the computer input, I noticed the color on my STB DVD player was now looking over-saturated, so here's how I resolved the conflict between the two video inputs.
First, I converted the Quick Color Corrector image in Post #2 to an SVCD, and put it in the DVD player. With this image, I determined the correct Color saturation needed for the DVD player per Post #2- Step #1. On my TV the value needed for the player was 50%.
So I set the Color setting in the User Menu back to the default of 50% (32 ticks). This, of course, made the computer input look de-saturated. So to fix this, I simply went into service mode and changed item 2170P-4/SCOL to 37 with the TV switched to the DVI input where the computer was attached.
2170P-4/SCOL is apparently the Sub-color adjustment for different video inputs. If you want to change the color of one video input relative to another, SCOL seems to be designed for this. Apparently, all one does is switch the TV to the video input desired, change the value and then store it. Anyway, changing that one item in the service menu for the DVI input rectified the conflict. And now both the DVD player and computer have correct color.
For good measure, I cycled through all the different 2170P-2/RGBS color modes with the Color Corrector on both devices after making this change, just to make sure the RYR/RYB/GYR/GYB Color decoder settings were acceptable for both devices, and they all passed. Now both devices are color corrected and look sweet. And here's what I ended up with...
User Menu
Color = 32 ticks or 50%
Service Menu Category 2170P-4
SCOL (for DVI input 1080i 16:9 Full mode) = 37
SCOL (for DVD YPbPr input 480i 16:9 Full mode) = 32
RYR = 15
RYB = 15
GYR = 7
GYB = 4
(Another setting that may perhaps need to be looked at for the most precise color is 2170P-4/SHUE, the sub-hue for each input.)
I don't know if this was the correct way to go about all this, but it seemed to work and make sense to me. As ever, record all defaults for each input/mode and use at your own risk.
Also, FWIW disabling the MID5/MHLY item for Pro mode as mentioned in Post #15 above has helped to make that mode much more watchable IMHO.
I've spent the past three days working through various powerstrip settings and I've got my setup just about where I want it and I was hoping for a little help to finish it up.
I'm connecting a Sony KV-HS32510 to an Nvidia GX5200 with 128mb RAM via a DVI-d cable.
The best resolution I have been able to acheive is 960x540p (60Hz) .I can go up to 1920x540 but that picture is garbage. The 960x540 picture is crisp...but there is some overscan (about an inch on the top and to the right) and if you look closely you can see some flicker...but it's very minor.
I changed the JUMP setting from 1 to 0 and that cleared up the forced 16:9 ...thanks for that one! If I could eliminate the overscan and the flicker then I would be golden.
Any help would be greatly appreciated.
1 - 20 of 149 Posts
Status
