Status
Not open for further replies.
1 - 2 of 2 Posts
Hi all,
I'm setting up my HT so I can use my projector or my monitor from my desk (or from the couch by the desk for movies/etc).
So, I did a lot of searching for switch boxes, and I am having problems finding what I need, and was hoping someone has already solved it.
I want to use my computer as the single DVI input, but have 2 OUTPUT selections for either my LCD monitor (DVI), or my Z3 projector (DVI-HDMI).
Is there a reasonable switch box (like something not $30+) available for a 1-input x 2-outuput configuration? All the ones I see are 2-6x1 configurations.
I'm haven't seen too many inexpensive dvi 1x2 switches. You may be better off with a video card with 2 dvi ports.
1 - 2 of 2 Posts
Status
