There is something I am not understanding about RGB balance to set the grayscale and how it is related to gamut errors.
I have a pretty flat RGB gray scale from 20% to 100% on my G70 CRT projector using a combination of projector Bias, Gain and a Lumagen HDP 11 pt gamma curve. However when I measure the primaries in the gamut, it says the blue primary is way too bright, with hue and color having small errors. I don't understand how this is possible and still have a balanced D65 white point. When I change the Gain control, I am changing only the intensity (lightness) of the color at the upper end, not the actual color as that is fixed by the phosphor and lens, right? If I lower the gain control so the blue primary's dL is low, the RGB graph says I have very little blue. So if the white point is balanced in the correct proportion of R, G, and B, which should only be intensity, how is any primary too bright or too dim?
What am I not understanding?
