1 - 5 of 5 Posts
I am looking to buy a 22" Monitor with DVI and DVI-SUB(VGA) connections, and I have an XBOX 360 PRO with an HDMI port on the back. I was thinking if I could use a HDMI > DVI connector to hook up the video up to my monitor, BUT, my only problem is the audio/speakers how do I get my 360 to output audio to my computer speakers. Thx appreciate the help. Also for my monitor what happens if I put a VGA cable in and DVI cable into my monitor, would my monitor have some settings in the menu to choose from which one?
These are the speakers I have.
http://www.canadacomputers.com/index...163&cid=SP.997
And this is the monitor I look forward to buying.
http://www.canadacomputers.com/index...005&cid=MT.282
Thx for the help guys.
Not sure about the 360 audio with HDMI if you want the audio to go somewhere else. I know there's a passthrough for digital audio, but maybe not analog.
If your monitor has multiple inputs, it should have a button on the front to switch between them.
1 - 5 of 5 Posts
