Status
Not open for further replies.
1 - 2 of 2 Posts
This is probably a dumb question, but it's not intuitive to me so I will ask it anyway.
I ordered a Channel Master 4221 (4 bow-tie UHF antenna) and it came a few days ago with no instructions. How do I hook up the antenna cable to the antenna? It came with a 75 ohm balun that has the 75 ohm cable connection on one side and two leads on the otherside that are in the shape of a hook. Do I just connect the hook end of this balun to some point on the wire rack? If yes, does it matter if it is on the bottom, middle or top?
MurrayW
Banned
You hook up the two wires from the balun under the wingnuts. Tie a coax cable to the other end of the balun. The balun should fit in the groove on the front side of the antenna.
1 - 2 of 2 Posts
Status
