1 - 4 of 4 Posts
· Registered
I have a 2008 MacBook Pro (which means no audio capability through my Mini DisplayPort) and a Yamaha RX-V667...My MBP is basically my HTPC with plenty of 1080p videos and 5.1 audio along with it
I have a Mini DisplayPort to HDMI adapter and a minijack to Optical adapter...is there a way that I can connect both of these to my Yamaha receiver and it will run the video and audio through it?
· Registered
probably. if you have problems visit the mac htpc forum on this site
· Registered
The receiver is capable of taking in HDMI for video and optical as the audio by assigning them together.
Go to "Input Setup" and select the HDMI (1-5) input the MBP is connected to. Then to "Audio In" and select the Optical (AV1 or AV4) input the MBP is connected to.
1 - 4 of 4 Posts
