1 - 2 of 2 Posts
When I purchased my house the builders prewired my theater room. They used coaxial for the sub connection. The wire only, no male/female connectors.
Is this going to be just as good in quality as a normal rca wire? The sub I have is the Outlaw LFM-1 EX.
I would like to try and find all the stuff I need on monoprice if possible. I'm not having much luck since I don't know all the proper terms for what I need. I basically want a wall plate for the coaxial cable and then something that converts the male end to connect to sub.
1 - 2 of 2 Posts
