This is tough to explain but I'll try.
Last weekend I installed a couple 2 gang 5.1 wall plates for my surrounds, sub, and zone 2 patio speakers.
On the rear wall plate (not the one behind the receiver and TV), only the sub and 2 surrounds are connected...the other half of the plate isn't being used. But the other half of the wall plate behind the TV is being used for my zone 2 patio speakers. I'd like to be able to use the other half of the rear plate to connect my Macbook for mostly audio, and maybe video.
What's the best way to do this? HDMI for video, but what about for audio? Optical? I can't seem to find a single gang plate with both HDMI and optical. I have found a plate with an HDMI and 2 RCA's at Parts Express . Will that work? Are there adapters to convert a digital coax cable to 1/8 so I can connect it to my Macbook's 1/8 audio out port? Or do I even need digital coax? Should I just go with the analog RCA's? I'll be using the Macbook to listen to music, browse the web, and watch movies/TV shows.
Thanks for your help.
__________________
__________________
