1 - 10 of 10 Posts
Hello!
I read the other thread about this, but found it confusing so thought a clearly stated response from someone might be helpful for all.
I have a Sharper Image Entertainment projector which accepts only a three wire connection.
I purchased this wire (CANT POST THE LINK, so it will look weird) i just cut off the first part to see if it would work.
.amazon.com/
VGA-RCA-Component-RGB-Cable/dp/B000FM3EQ0
Which doesnt work. I think it is the wrong wire however, i thought as long as the plugs on the end looked right it should be ok.
I have tried connecting it to 3 computers.
What do I need to make this work? Just a proper wire or something for encoding? I would like to get it right before i spend more money...
Alex
Originally Posted by AlexandrePrime /forum/post/20866242
Hello!
.amazon.com/
Alex
what is the model of the computer and what is the projector?
looking on amazon and reading reviews(which I think you didn't) it seems like that cable doesn't work for what you need
you need something like this
http://www.digitalconnection.com/Pro...Video/9a60.asp
I believe that toy projector has Component Video .. Amazon still sells the unit and offers the add on video cable for VGA to Component Video
A VGA to component adapter is only going to work if the video card supports it, I don't know of any that do. Most of the videos that supported Component out that I've seen used a DVI to component(ATI) or a mini din style connector to componet(Nvidia) dongle. There are VGA to component converters if non of you video card supports component out even w/ the correct adapter/dongle but they're pretty expensive and don't seem to give as good picture quality as using a video card that supports component out w/o it.
BTW Component has 6 wires not 3, each connector has 2 conductors and normally uses a 2 conductor/wire coax cable for each connector w/ all 3 coax cables commonly molded together and split near the ends.
Discussion Starter · #6 ·
Thanks for all the responses.
I did not read the description on the wire before i bought it - guilty.
Projector is a Sharper Image Entertainment projector.
Computers include Dell mini, Dell vostro, home built desktop with a video out that is a plug for a "flat panel display" part of the plug has a little cross shape and I just have a converted to make it VGA.
This is still a little confusing! So my issue here could be that the projector WANTS component inputs.
Dvd players, video game consoles and PCs put out RCA - so this is the mismatch?
I have connected a TV to my laptop and had it work, and Ive connected a WII to the projector and its worked, and ive connected the WII to a TV and had it work so it seems like they are all using the same communication. I lost the wires I had for the laptop to TV.
So if I am on the right track i should just get the wire and it will work?
I feel like im going to get schooled after this post.
Alex
Alex
component=3 cables just for video, HD capable
composite=RCA=1 video cable, usually goes together with 2 audio cables
you effed up and bought a component converter when you need a composite because that projector doesn't take component, unless the pciture I see is wrong
I suggest you try one of these
http://www.amazon.com/gp/product/B00...93QF06M1RRC06F
if it doesn't work then you need a converter in which case don't bother because the projector is kind of a joke
Discussion Starter · #8 ·
Yes, I eff many things up :)
Basically this would have all been simple and I made it complicated by getting the wrong wire.
The description of the 3 wires for component video and 1 wire and 2 sound in the normal wire is very helpful, thanks.
The projector is meant to be a very low cost, low space requiring way for me to watch movies in my room. It was $80. Hopefully the quality is good enough for this! I am surprised at how hard it is to get a cheap used quality projector when it seems like they have been around for long enough.
I dont see a way to mark this thread as solved, but IT IS SOLVED. I will post if it works when i get the wire in the mail.
Thanks for all the help this seems like a good community of smart direct speaking people.
Not sure if you can return it but if you want a projector on a budget I am suggesting ebay
http://www.ebay.com/itm/TOSHIBA-TL-P...item4aae1c8809
Discussion Starter · #10 ·
Yes I suspect this one will suck pretty badly. It was a craigslist buy and I thought sharper image had a reputation for quality. You just have to touch the thing to know its a piece of junk, BUT some of the reviews say it has surprisingly good quality.
When im ready for an upgrade ill return here and have my selections vetted.
1 - 10 of 10 Posts
