Hello All,
I just purchased 2 of the EchoStar TR-40CRA units, one to connect an LCD TV + VCR, and the other unit to connect another LCD TV + DVD recorder. Both LCD TVs have their own ATSC tuner, so I wanted to use one output from the CECB to connect to the TV using analog passthrough so that the digital signal goes directly to the TV. The other output from the CECB would go into the VCR or DVD recorder unit and would require the D - to - A conversion, since neither the VCR nor the DVD recorder has an ATSC tuner. The User Guide for the TR-40CRA does not address connecting the CECB to a VCR or DVD recorder.
I purchased this model CECB because I understood (from a discussion I started on another AVS Forum thread a while back) that this unit would allow me to accomplish what I describe above without my having to purchase splitters. But now my little head is hurting: how do I make the connections to accomplish my goal? Do I use the coaxial output connection on the back of the CECB to connect to the TV, and the composite (RCA) connection on the back of the CECB to connect the DVD recorder (or VCR), and then run the setup wizard on the CECB for the DVD recorder (or VCR) connection?
Help!!
Doug
Help!!
Doug
