Status
Not open for further replies.
1 - 2 of 2 Posts
I just bought a creative labs Audigy 2 sound card and a sony 895 receiver. I wanted to know if i can connect the optical connection of the sound card into one of the receiver optical inputs. Will this work and what kind of hardware will i need? any other info would be great
thanks
mike
I have connected the Optical output of my Delta DiO 2496 sound card in my HTPC (home theater personal computer) to the optical input on the rear of more than one receiver. It works just fine. The only hardware you need is the computer and receiver. The only media you need is the optical cable.
Check the HTPC forum listed on this website for more information about what you can do with your computer for home audio and video purposes.
1 - 2 of 2 Posts
Status
