1 - 2 of 2 Posts
What cord/cable is used to connect a portable tape player, such as a walkman, to the auxiliary port in a car radio?
The connection would link from the headphone jack of the tape player to the auxiliary port.
I am not familiar with these cables, only those with some functional device on the "other" end, such as headphones or a tape adapter.
New cars lack a tape cassette option, which is why such a port would allow me to still listen to tapes through the car speakers.
Can't believe this got 30 views without an answer...
Its a 3.5mm to 3.5mm cable (male on both ends). 3.5mm is also known as 1/8th inch. Should be able to pick one up pretty cheap/easy at radio shack, although if you're willing to search Walmart they might carry it for less.
1 - 2 of 2 Posts
