1 - 7 of 7 Posts
I am getting myself confused with the order in which to connect the following components:
  • Sonos ZP80
  • A DAC
  • Pre Amp
  • Power Amp
  • Speakers
Should I go:
Sonos ->DAC -> Power Amp - > Speakers ? Or
Sonos ->DAC ->Pre Amp -> Power Amp - > Speakers
Is the Pre Amp necessary in this chain?
Interesting setup, to be sure. You'll need the DAC to get an analog signal, the preamp for volume control (unless you want to buy a separate volume control), and the amp to.. amp.
So you will go Sonos -> DAC -> Preamp -> Amp -> Speakers.
Discussion Starter · #7 ·
What happens if I eliminate the preamp and go directly from DAC to power amp? Is that a no no? ( assuming the power amp has volume control ?) My DAC has volume controls too.
Sonos -> DAC -> Amp -> Speakers.
ps: Why is it an interesting setup? Is it unsual?
1 - 7 of 7 Posts
