1 - 5 of 5 Posts
· Registered
Hi all can u guys give me a hand regarding this questions thanks. Here my setup connecting to a LG 32LC2R for now (yes its old and small) (connection types here) http://www.afterdawn.com/hardware/pr.../323/lg_32lc2r
Window XP PRO sp3
CPU: AMD x2 7750
Motherboard: Gigabyte GA-MA78GM-US2H (build in ATI 3200 video card)
RAM: Kingston 2gigs DDR2-800
HDD OS: Seagate 500GB
HDD: Storage Seagate 500GB
Case & PSU: Coolermaster CAC-T05 with 460w
Optical Drive: Pioneer 118 DVD Drive
Motherboard has these connection types: HDMI/DVI and optical for sound
My questions is:
1: what the best way to connect this PC directly to the LG 32LCR2 (since the TV and the mobo has HDMI sound like i need to use 1 HDMI cable for connecting right? will i get sound as well as video through this?.
2: If i buy a Yamaha AVR 1900B what the best way to connect?. Can i connection 1 HDMI cable from my PC to AVR and another HDMI cable to the TV. Or 1 HDMI cable to the TV and a Optical cable from the PC to the AVR?
Oh i believe i need to install this ( ATI HDMI Audio Driver ) to work properly with HDMI on the mobo?
Please could u guys answer to both questions.
Thanks in advance.
· Registered
Hey Peter,
1- HDMI to TV. I couldnt figure out from the TV manual (badly done btw) if your TV set is HDCP compliant but it should be.
2- Don't bother routing the HDMI to the receiver. Just use an optical cable from the mobo to the receiver.
3- The latest Catalyst 9.7 driver set is good for the HD3200. You'll find the HDMI audio drivers together with the onboard audio driver on the Gigabyte support site here:
http://www.gigabyte.com.tw/Support/M...ProductID=2995
Careful: check if your mobo is the REV 1 or REV 2 of this model number.
Enjoy!
· Registered
Discussion Starter · #3 ·
Originally Posted by Digital_Snacks /forum/post/16906768
Hey Peter,
Enjoy!
Thanks for the help
Firstly Regarding the HDCP not 100% sure but the TV does have HDMI port. Now if the TV is not HDCP can I use AnyDVD to over ride that for that to work?. Or should i get a DVI-HDMI cable instead (or this also need to be HDCP as well?)
Secondly i thought i need the ATI HDMI Audio Device driver according to this thread http://www.avsforum.com/avs-vb/showt...blingHDMIAudio for it to work for sound or the Gigabyte link is the same thing?
1 - 5 of 5 Posts
