Hello! I didn't want to hijack fastgt79's thread, but part of my question is exactly what he asked in his/her thread (sorry, can't post the url yet!).
I am ready to get going on refinishing my basement, and installing a home theater in a 22x16 room. My goal is to be able to enjoy movies/music with minimal sound moving to the rest of the house. My expectations are not that I can completely contain the sound, due to several factors (not the least of which is cost!) Based on my experience, the biggest concern will be sound traveling through ductwork.
I imagine my situation is like that of many people out there: What is the right point on the price/performance curve? Doing a decent job will cost x dollars. More money will yield better performance. But at a certain point it stops being worth it.
Current state: Open joist ceiling, finished walls, carpet (will be replaced).
Complicating factors: 1) HVAC ductwork running through the room from the inside heat pump unit, 2) Staircase to upstairs is adjacent to the home theater area.
My current plan is:
1) Insulate the bays between joists (was looking into cotton batting, but just getting it is becoming too tough. May just put a few layers of fiberglass, loosely filling the space).
2) Hang resilient channel, with isolation tape, across joists.
3) Hang two layers of 5/8 sheetrock, with green glue in between. (After reading and researching here, I'm moving away from my previous plan to use QuietRock.)
4) We'll be installing a suspended ceiling also at a minimum drop (wife-requirement). Looking at low profile LEDs for lighting.
5) I plan on boxing the ductwork, using a black foam mat (3/4 or 1 inch) on the sheet metal, then building the box with 2 layers of 5/8, with the green glue.
6) Also thinking about attaching black foam to heat pump unit, which will be protected by a solid core bi-fold door.
7) Replace door at top of stair case with solid core door, and insulate top and sides of jamb, install sweeper at bottom of door.
Looking for feedback and perspectives in these areas:
- Will this work well enough? Is it too much (due to the inevitable weakness with the staircase)?
- What about the HVAC register and return vents?
- Will resilient channel be able to hold two layers of 5/8 sheetrock?
- What am I missing?
I'd love to have the papers Ted White offered to fastgt79, if possible
Thanks in advance
My current plan is:
Thanks in advance
