5) you plug your wireless speakers into an outlet, it has an internal receiver and amp. I don't understand why you would take that shortcut if you are doing construction, just put speaker wire in the walls.
7) a acoustical treatments to make your audio sound better does not go in the walls, they go on the walls. Sound containment goes in the wall but we are not talking about just insulation. Mass, Isolation, Dampening and Absorption are the ingredients that need to go into your rooms construction. If your contractor tells you they can use some special insulation, they are selling snake oil.
