1 - 4 of 4 Posts
· Registered
If a LCD has a difference of 30,000-50,000:1 contrast ratio from a higher end model in that same class.......can 30,000 alone make a big difference? I'm comparing the Samsung ln46c600 vs ln46c630 vs ln46c670. These 3 all use the same panels from what I have read. I'm debating taking back the 600 for either the 630 or 670. Please help.
· Registered
Discussion Starter · #4 ·
Originally Posted by neuspeed /forum/post/19571776
Yes there is a bit of difference. Do you not like the 600? Also is the difference worth the extra monies? What are your settings? I have the 600 and like it also.
I like the 600, but you know how it goes when there is something a bit better.
I'm just using the standard settings right now.......would you mind sharing your settings?
1 - 4 of 4 Posts
