1 - 5 of 5 Posts
There are a couple of devices that will convert the blue tooth signal of the PS3 remotes to IR. Do a search for Ir2BT and PS3ToothFairy. Either of those two should do the trick.
I think there is one other way. If you buy the blu wave remote from nyko (around $15) (i think that's how it's spelled), it comes with a usb dongle. This will allow you to control the ps3 through that remote and then you program the logitech with those buttons, you should have control over your PS3. One caveat, you won't be able to map the PS button. From what I can tell there is no mapping to the harmony remote from the nyko.
As for the Wii... you're in the wrong forum to ask that question. I would check in the Wii forum as well as in the remote control forum.
Good luck and hope this helps.
1 - 5 of 5 Posts
