Controlling Temperature in Component Cabinet
405 Views 2 Replies 3 Participants Last post by  DoyleS
All my HT components driving 2 rooms are on a portable cart in a coat closet. The cabinet has the following components: 2 X A/V Receivers, 4 X Cable Boxes, 4 X DVD Players, 3 X Game Consoles, 2 X TiVo's, 1 X D-VHS.
When I keep the doors closed the temperature goes as high as 104F in the coat closet.
I need some help to cool my coat closet down. I don't think it is good for the components to run that hot.
I was thinking about the Panasonic Whisper Quiet Fan??
http://catalog2.panasonic.com/webapp...noreRedirect=1
Any one else doing the same thing?
Please share your experiences.
Kind regards
Johan
See less See more
Status
Not open for further replies.
1 - 3 of 3 Posts
I installed a Panasonicfan in my under the stairs equipment room.
The house is still under construction so I cannot attest to the actual performance but in the show room they are very quiet. They make several different CFM units. (I used the 90 cfm w/light) unit as it is quieter than the 110) I would say most closets could use the smaller 70?cfm unit, they are even less noise.
I have a similiar problem only the equipment closet is very small. About 2.5 x3 ft. Mine is on the ground floor and I chose to cut some holes in the floor and have a small computer fan that takes cool air from under the house through a filter and another that blows air from the closet back under the house. System is still under construction but I think it will work pretty well as the under house air is rarely as high as 70 F. It will operate on a thermostat.
..Doyle
1 - 3 of 3 Posts
Status
