Status
Not open for further replies.
1 - 2 of 2 Posts
· Registered
I have noticed that text get's blurry after a while when running my HTPC Desktop. I am running my Radeon 7500 through a mitsubishi 65819 at a 856x484 resolution. Is this a normal thing? It appears that both the blue and the red convergence need to be adjusted periodically (every 8 to 10 hours).
Any help or suggestions.
· Registered
Are you using a CRT projector? If so, it takes 20+ minutes for the tubes to properly warm up.
---If this is the case you should let your projector warm up at least 30 minutes before you converge it. You may only notice the misalignment more with your HTPC than any other input b/c it is so much sharper.
When I had my CRT I had to reconverge it at least once or twice a month. They are very fragile when it comes to humidity & temperature. One of the reasons I'm truely loving my DLP projector!!
1 - 2 of 2 Posts
Status
