Hi,
I am thinking bying sony vpl hw55 but problem is my room size. Its only 2.68 (8 feet) metres long and sony takes 46cm of that so I could only produce about 1.5-1,6 metres wide image with sonys throw ratio and my goal is 2 metres or even 2.2 metres wide image.
Is there any compatible conversion lenses which would fit to this model with reasonable price tag.
For example I found this http://www.amazon.com/Sony-VCLHG0758-Performance-Conversion-diameter/dp/B000063XWC
In the comments one customer says. "Does a great job of widening the viewable image on a projector at short distance"
Is there any better lens options? or other options? does the quality of image suffer from using lenses?
